Hallo Leute,
Hat schon jemand Erfahrungen mit anderen Kolben in der 690er gemacht?
Habe gerade auf dem Blog von Rally Raid aus England gelesen dass sie derzeit welche von Cosworth entwickeln lassen, die sind von der Qualität sicher top, auch wenn der Preis nicht gerade günstig ist.
Gruß,
Lukas
Zitat von ktmmitch;22924397As a by-product of our quest to build a short-stroke LC4 motor, to reduce it to 450cc for our upcoming Dakar project, we are having a batch of 48 pistons that have been designed & manufactured by Cosworth Engineering here in the UK.
Some of these will be std compression and some higher compression to suit the 654cc & 690cc motors, that is 102mm bore in either 80mm or 85mm stroke.
Std compression pistons will be 11.8:1, and the hi-comp ones will be 13,5:1.
As expected, the quality of these will be second-to-none, and will be supplied with piston rings, gudgeon pin and clips.
We expect delivery by late Feb/early March.
Prices for either version, with ring kit to be £370 plus VAT & shipping.
