I am fitting a 2013 motor into my 2009 r frame and this seems ok till I found the neutral switch is different. I cant swap the switch over as the end of the gear shaft is different and the switch a different design.
I dont have a 2013 wiring diagram to help.
The early version has four wires at the sensor one of which goes directly to earth and three wires go to the plug to the loom.
The later design has four wires all of which go to the loom at a four pin plug
I am thinking maybe one of the four could be earthed and the rest put into the earlier 3 pin plug to the loom. but maybe This is too simple ?
any info would be great
Thanks
