hi, i just bought a 1290 super adventure and I am very disappointed about the chain noises,
if some one knows how to avoid noises or even with an aftermarket parts.
its a shame to spend 20,000 euros on a bike and have that isues.
Chain noice
- 1290
- eraklisc
Have a look for the same issue on the 1190 Adventure. Mostly it seems to be a problem of a misadjusted chain tension.
To weak or to strong adjusted, or maybe also a bit too dry.
Das ist genau der Punkt, sie reagiert mit Klappern auf eine unkorrekte Kettenspannung. Hatte meine 1190 bei Auslieferung vom Händler auch, korrekt nach Handbuch einstellen und es ist Ruhe.
Giassu file! Ola ichame problema me tin alissida" sound". Ine normal......LATHI theli!!!!! To kalitero ine, otan agorasis ena chain oiler. Iche ena scottoiler
http://www.scottoiler.de/websh…fo/p230_NEU--KTM-Kit.html...ena alli oiler ine, efkolo systema:
http://www.tutorochainoiler.co…re/auto-motorcycle-oilersi, tha grapsis to enas pu ine etho sto forum. To forum onoma ine "Hobbit".
http://onlineshop.cls-evo.de/index.php?page=product&info=107Iche ena Thread prin liges meres apo to systema etho, boris na wlepis fotographies:
[1290] CLS EVO an 1290 SAOtan grapsis sto "Hobbit"....aftos katalaveni agglika......no problem!
cheretismata ke "good luck"!
Oder so.
hi.
thanks for the respond ,but i have sprayed the chain with motorex chain lubricant adjust it correctly and its very noise when the road is not so smooth.
the sound is like driving an enduro bike in the gravel and the tensioner is loose.
