TLDR: Gibt kein V3 mini und V3 150mm auf absehbare Zeit, auch nicht wenn er schon bestellt war.
Der Originaltext:
Hello,
I hope you are well,
It has been brought to our attention that the V3 mini 140mm can and V3 150mm can options for the KTM 2014-19 and 2020 1290 SDR models have been failing roadside Db testing in certain European counties,
We believe this may be due to the method of roadside testing not being up to the homologation standards or through the use on mis-calibrated testing equipment, however due to this we as a company are removing these options from our homologated can choices with immediate effect until this issue can be rectified as a precaution,
We as a company do not wish to leave our customers in a position where their exhaust system/motorcycle may be falsely impounded and subject to fine when used, as these systems were designed with the sole purpose of road use,
With this in mind we are contacting all customers with pending orders to offer the following choice,
We are happy to exchange your current order for one of the following three options, either the V3 mini 200mm which is the same as the V3 mini only 60mm longer or the V3 200mm/250mm all of which can be seen below, simply reply to this e-mail with your preference so that we may adjust accordingly,
If this solution is not suitable or you would prefer to continue with your original order in the same length but in a non-homologated configuration then please do make us aware as soon as possible so that we may adjust this accordingly,
All the best,
Kyle
Office Manager
