es gibt echte Profis die das hier schreiben:
Note from Lyndon:
“I strongly recommend installing with a valve clearance of 0.04mm to 0.09mm both Inlet and Exhaust valves to ensure the best life from these items. We have tested valve clearances extensively on the dyno and I personally ran these valve clearances with these rocker arms on Races to Places with no issues in the last 160,000km. I would recommend preventative changes at approximately 25,000km as they are a wear item and in my opinion they should be a service life item” – Lyndon
Lyndon Poskitt - Home
Lyndon Poskitt Racing is your place for the ultimate motorcycle adventure, equip yourself, challenge yourself, improve yourself, and make memories for life.
lyndonposkittracing.com
ich persönlich aber würde das Spiel erhöhen...lg
