Hello,
owner of a Duke 690R 2011 with 2550km at the moment. Also just installed Evo 2 kit .
Here below todays dyno :
74,3 hp @ 7723rpm at the wheel and
7,6m.kg @ 5879 rpm torque.
Take care all ![]()
Hello,
Take care all ![]()
i think, the dyno is broken
these are nearly unbelievable values (at the wheel)
if the dyno is not lying, that are nice results for a -r+evo2 ![]()
it was a fuchs dyno . i dont know if it was broken but the owner is the
engineer of a local supermoto champion and its considered decent.
i know that normal duke 690 R is around 66.6hp at the wheel.
so its not so crazy to see 74.3 with the complete evo 2 kit .
74 rwhp for an 690 Duke R , including the evo 2 kit , it's very normal , and i know what i am talking about , my engines , even in 693 cc give's 90 rwhp ![]()
working hard gives always result , and i am happy for you Glockan ![]()
Thanks fd,
I am really proud as well! But still as i said i have some minor issues when i installed the kit.
The bike some times runs alone at 2000-2300rpm with the clutch engaged.
But 90 rwhp it's reallyyyyy impresive!!!
Thanks fd,
it is impresive to ride !!!! front wheel always on air
the trouble you'r teeling is typical for this setup , other riders has the same problem , i thing the map is to lean , it needs more fuel at the idle ![]()
how do you correct the fueling? Is it possible with the
original KTM tool or do you need something like tunecu ?
i use my own digital injection/ignition , with 2 injectors ![]()
