hat hier jemand schon dieses versucht?
http://www.rottweilerperforman…ler-fueling-dongles-pair/
"The Rottweiler Performance 'Fueling Dongles' are an effective and simple method to improving the fueling mixture of any fuel injected KTM by allowing the stock ECU to deliver a proper mixture at low to mid RPMs. By replacing the stock narrow band O2 plugs with these simple to install dongles, the Rottweiler Fueling Dongles feed the stock ECU a pre set signal that substantially smooths out the lower end power delivery reducing the jerky transition between the extremely lean low RPM mapping and the open loop upper end mapping. Overall average air fuel ratios also tend to richen up by about .5 to 1 point as well allowing the user an inexpensive option to 'bump up' the richness of their fuel delivery if the cost of a Powercommander is not currently an option for them. "
