http://www.ktm.com/at/enduro/690-enduro-r-eu/highlights.html
hat jemand nähere infos was jetzt der unterschied zum 2013'er ist? abgesehen von der neuen farbe und des abs?
hier einige infos aus nem anderen forum:
1. ABS für front & rear
2. Twin-plug 690 Duke motor fitted.
3. Lower fork changed to allow fitment of ABS sensor.
4. New electronic throttle from Duke 690, and new throttle/front brake cluster.
5. Frame looked the same, apart from repositioned rear brake reservoir, and coil removed to as 690 Duke motor has twin-plug head, with inboard coils.
6. Forks changed to left leg compression damping, right leg rebound damping.
7. New airbox, with repositioned sensors.
8. New ECU, only 1 fitted now.
